technical wheel sizing help needed please
MELLOWYELLOW06
I came across a set of aftermarket wheels
I like for our 2015 Yukon XL 4x4
They are 22" X 10" wide. I want to run 305/40/22
tires to keep it as close to the factory 20" diameter stockers.
My only concern is the et 40. Is that too high of an offset? Will wheels stick too far in the Fender or will it be just right?
Thanks in advance
158079[/ATTACH]
08grey
With 40 you have to worry about it touching the inside shock Ect I believe. You can add a hub centric spacer if needed. 305 is likely to rub. 295 would be a safer bet.
ewgaul
