Temp Control unit swap?
StephenC
So I have a 2001 Hoe and am thinkin of converting the 1.5 din to 2 din headunit and I'm trying to decide if I want to modify my current bezel or buy the 03+ bezel. My question is will the 03+ Temp Control from an 03 work on a 01? I know it would fit if I change the bezel and the frame behind it but would it plug in and function properly?
S
StephenC
buy an 03 bezel
Thats what I'm more than likely going to do but I dont want to use the 2001 climate control with it because I heard people say that the bezel pops out alittle and it covers up the defrost and blower speed alittle bit. So if I am going to do the 2003 bezel I would like to use the 2003 climate control with it so it looks better. So do you know if the 2001 and 2003 harness for the climate control are the same and everything will still function properly?
S
StephenC
The first climate control is the one that I curently have and the 2nd is the one from the 03 the size I'm not worried about, its wether or not everything will function properly?
BurbyRST
