Hello all, and let me say thank you in advance for any and all help. It is greatly appreciated.
So, it goes like this... The other day I went outside, (I live in MI so it has been very cold) and I started the truck. I usually let it sit and run for about 5 minutes or so to warm up enough for the heat to kick on.
I have a 1999 Tahoe 2WD 4 DR 350 Vortec.
After a few moments I went outside to get in the truck and I noticed that the heater vents were blowing cold air. I then noticed the Temperature Gauge was just past the halfway line. Usual running temp, even in the summer when hot, is just below the 1/4 (quarter) line.
I first checked my coolant level. It was a little low, but nothing too bad. It has shown no signs of leakage. That didn't help. So next I changed out the thermostat but that didn't seem to do anything either.
So, while driving, sometimes the temp will shoot up to past the halfway mark and then start to creep up even higher. However, most of the time if I put it in Neutral and race the motor the temp gauge drops back down to normal. When the gauge is high it blows cold air but as soon as the gauge drops down to normal temp the heat kicks back in and works very well.
Someone told me this could mean I need a new fan clutch, so I went ahead and changed that out. It is still doing the same thing.
Next I went and had the coolant system flushed and re-filled and it seemed to help a bit. I drove it for the next two days and the temp was running just a line or two higher than normal, but it was steady and the heat worked fine. Today though, it started to do the same thing again, where as I was driving the temperature would start to raise and the heat would go off. Then, after racing the motor a bit, it would drop back to normal and the heat would kick on.
Now someone is telling me I should have the heater core flushed because it could be a blockage. I just wanted to get some opinions from you guys, who know a lot more about this sort of thing than I do, before putting any more money into something that won't fix the problem. This is not only my first Tahoe, but my first Chevy as well. I bought it about 6 months ago and this is the first time this has happened. There were no warning signs before that first day.
In any case. Sorry for the long post but I just wanted to make sure I was as thorough as I could be. Any help would be great. Thanks.
Chris in MI
Chris in MI
