Temporary Cluster issues 2010 Tahoe
chilleblanco36
Weird thing happened this morning in my 2010 Tahoe. Started it up and only gauge working was the voltage gauge. Tpms was blank, oil pressure was 0, fuel was flat, and neither speedometer or tach was working. I drove a few miles to see if it would pop back on. It didn’t.
I stopped and turned the truck on and off a few times, then everything went back to normal. Now it’s working fine the last few times I’ve driven it today. What’s the deal with that?
S1W99
I got the same problem but all my gauges are reading zero but the cluster lights come on. Did you ever get a solution?
BG1988
the soldering more then likely cracked it's pretty common ... check out
jeffescortlx on YT he repairs these units
does the display come on?
pipehand903
