Discodisco
- Joined
- Oct 21, 2024
- Posts
- 25
- Reaction score
- 13
My escalade keeps throwing a p0011 vvt code and has a very slight intermit misfire. Ive replaced the cam sprocket/ actuator, bolt/valve, magnet, sensor, and timing cover harness in one shot but the code comes back. If im driving to the on the freeway for 60 miles it will come on and go off like 5 times. Idle oil pressure is 20psi, 2k cruising pressure is about 50 so I dont suspect a cam bearing issue. The vvt responds normally when im doing the actuation with the scanner at idle. What am I missing? l92
