Throttle body cleanings ?
sick1166
2007 4.8 Do I need to take it off to clean the tb
I have 110,000 miles and the truck runs great but thought I should do some cleaning
Someone told me to leave it attached?
OR VietVet
Multnomah Falls
Military
Willamette Valley
You can clean it on the rig. Get a very clean cotton cloth and some carb cleaner and open the throttle plate and clean the areas where the throttle plate seats when closed. Clean the edges of the throttle plate too. A soaking of the cloth and reach in to rub clean is sufficient. Get some Mass Air Flow Sensor cleaner at the parts store and follow directions to clean the MAF. When restart don't be surprised about a higher than normal idle and just drive the rig for 10-15 minutes and the system will relearn and then should be ok.
08grey
Try not to move the plate that much. Nooce it once and keep it steady and do your cleaning.
Mr. Merk
Yeah I recommend it every 15,000 miles or so to keep it nice. It take just a few minutes.
tsuintx
DFW
Yup. No need to remove it unless you really want to. I cleaned it while installed and got it looking pretty shiny again. The idle stuff can be a bit scary, but it'll go away after a day or two.
crotonevans
I thought I was told never to open the plates?
can I open them ? press on gas pedal?
I am looking to do this for a while and was worried about moving the plates!
OR VietVet
Multnomah Falls
Military
Willamette Valley
You can open them but do it slowly and don't slam open. 08grey is right, don't open all the way to WOT. Open just enough to do the cleaning. tsuintx is also right about the idle relearn. I have seen it come back to normal within a 10-15 mile trip and I have seen it take longer like he said. If you want to use someone else to hold the pedal it is ok but no WOT and slowly.
crotonevans
WOW easy job thanks raiderron, unfortunately mine was so dirty I had to take it off ,my battery was out getting replaced, so I don't know if that had any affect on it but I had no high idle started smooth and ran great thanks to the great people on here with all their help
crotonevans
yes very dirty as well never thought of it till I read on here about the oil from my kn filter
thanks again
now on to the front suspension
dphi2602
