SunlitComet
OBS Jedi-Do Good
no point in porting so much that the tb outlet is bigger then the bore of the plenum and putting an adapter to knock it back down is pointless.
^ never heard of this mod before... Im gonna need more info and pictures and a write up please...
Post 3 has the link I used.
I will be doing this soon, or getting a 454 throttle body. It's a little bigger than the 350 one. it can also be ported larger than the 350 can. No noise reduction blade on the 454s either. Not a direct swap though. The 454 shaft and return spring must be swapped out for the 350 shaft and spring.
