Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
So, I got my 20's put on yesterday and wanted an alignment. Shop tried to get me for hubs and tie rods.....$600
I ran out.
How can I check them myself and are they easy to replace?
Thanks
So I drove 2 hours, some traffic and some aggressive highway driving. When I reached my destination I popped of my drivers side center cap and put my hand on the hub. It was warm/hot but I could leave my hand on it comfortable without getting burned. Is this normal or should it have been cool?
I went to a very reputable shop and they told me my bearing were too worn to hold a proper alignment. They quoted about $750 for the repairs and alignment. I bought Timkens off eBay for $230 a pair and installed them in about 2 hours. The old ones had no markings so I'm unsure if they are originals. One had a noticeable layer of fresh grease on the exterior. Over time this one may have had a complete failure due to lack of lubrication but at the time of removal both were smooth and quiet.
You can check for play in the wheel bearing by getting the front end off the ground. Push on the top of the tires. There should be some play, but not a lot. I had to replace both of mine on my 01 rcsb.
Well they are def worn. Went for an oil change and got a price. $1050 for Timkens installed lol. I just ordered 2 Timkens for $220. I'll learn how to do it myself.
you shouldnt have to much trouble installing new bearings just make sure everything gets torqued down correctly it mite be a little different on a SUV but ive large diesel rigs
and there was spacific way to torque down the hubs correctly
Wow must be hub bearing season. I had the same issue. I went for an alignment. They said cant do because of bad bearing. Only one side had play. I had them do the one and my alignment...$500. Coulda done myself but I didnt feel like going back for the alignment and losing another 3 hours of my life. Plus I'm going on a roadtrip Friday so not much free time before then.
I'll get the left 1 and repalce myself on my next 7day stretch off from work.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
