Tire Alignment AFTER drop
sickpup
Folks,
Are you getting an alignment after getting these drops. Is there enough travel to set the castor/camber/toe in/toe out.
Bout to buy a kit but dont want to buy 1000$ in tires in a month because the vehicle wont go into factory alignment.
Thaks
jeff laing
Folks,
Thaks
I have a 3-5 drop and all went back to spec no prob
drakon543
i dont know about lowering a suv/truck but i know they make special alignment bolts that can also push an alignment farther than stock setup. so you should be ok with a kit and possibly an extra 100 bucks for special hardware.
olyelr
Elk Rapids, MI
Depending on how low you go up front, it should go back into spec no issue. But it will certainly need adjustment.
NeverSatisfied
eBay Baller
Wichita, Kansas
Normally anything over 4” will need camber bushing or new can plated to get back to factory alignment. Most 4” or less go back no problem. There are always those cases where the exact opposite happens and more then 4” align fine with no issues and less then 4” needs help
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Yea you should get alignment anytime you change or work on suspension parts. There’s isn’t an adjustment for the rear camber, toe. I lowered mine using spindle drops in the front and had no problem with camber and toe
2016YUKONSLT
I bought Norcal SS 2/4" kit before he had spindles.When I had the kit installed, the place could not get the camber to 0 degrees. After riding around on it for a about 8 months(15k miles), I needed a new set of tires. I took it to the dealer and they tried to adjust it and the tech said the offset bushings were installed backwards. I called Tony (Norcal) and asked him about any camber issues and without hesitation he said the offset bushing were in backwards. Sent him a few pics and it confirmed that they were backwards. The dealer tech put them in correctly and now I have no camber issues.
OptimalZ06
