Tire help?
Josh w
I have an 08 suburban z71 I just ordered the rough country leveling kit (the piece under the strut) Im also going to change the wheels to aftermarket but what is the biggest tire size I can with little to no rubbing.
01Konvict
Boats n Hoes
Raleigh/SML
Tire depends on wheel offset for your aftermarket choice, most likely 275/60R20 or 295/55R20
al2fast
Wisky
Like Wade asked, what offset? I recently installed 0mm offset wheels with 275 60 20 tires and I had to trim front and back of the wheel well. Front is mega easy, back isn't bad either, just takes longer because you are cutting through metal and I removed my steps when I did the metal cutting.
Roblusk
