Tire sensors help
revbuilder
IL
I just got new OEM polished 20's and new goodyear wrangler ATS tires for my 07 tahoe, the rims have the tire pressure sensors in them. so when I first put them on and started it up the DIC came on saying to relearn tire postions so I went through all that and now it is saying to check tire pressure on all for tires, I have Goodyear ATS tire size 275 65 20 all 4 set at 55 lbs , they are a little taller than stock. Thanks for the help
Modded
That Guy
The 55lbs of pressure is your issue. Hot or cold, ths Tahoes are calibraated to start bitching when its at 28- 30lbs of pressure, or at49-50lbs of pressure. So 55 pushed it past the limit. Regardless, 55lbs of pressure on that tire seems to be overinflated.
The only reason why I say this is slim profile tire are meant to have a fair amount of more pressure than stock sizes, and with my 305/30/26 I run 42-44lbs with the highest recommended being 49lbs.
I say you reduced those thing down to atleast 45lbs COLD and you will be fine ,and won't go through tires for overinflation.
Mrsharza
