tires question
Saodrin
Pennsylvania
So today coming home i noticed that when i tryed to burnout the tire just hopped a bit and when i turned the rear kinda slid so i got out and checked i had a flat.. its a slow leak i found out but i need a new tire anyway cause it bald. i dont want to waste money on 1 31 inch tire when ill be buying 4 33s x 12.50 soon can i fit 33s x12.50 in the rear without lift untill i get the lift on for the 33s upfront
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Is there sufficient space between the fender and tire in all areas in front of, on top of, and behind the current 31 inch tires? If you base the measurement of 33's as being a one inch increase of radius (assuming diameter increases by two inches) the difference in tire-to-fender spacing should decrease by approximately one inch. If there isn't much space the slightest roadway bump may cause fender to tire contact.
bowtiefreak
No Quarter
Near Philly
I ran a procomp AT 33/12.5/16 on my stock rims with some rubbing over bumps but yes they clear
Bradford333
