TPMS---Help
fftrmedic
Tried to reorient my tire pressures to the correct positions after a rotation and now the computer is telling me that the TPMS (Tire Pressure Monitoring System)needs tobe serviced. Can anyone help?
llllljrlllll
los angeles
This is a wild guess, but have you tried disconnecting the battery, it might reset the computer, thus resetting tpms.
Cobra
Austin, Tx. area
If that don't work trying going to a discount tire co. or something they can usually reset it for you.
rir9005
what car do you have? Because in the owner's manual, you find the instructions to reset them. At least i found mines there.
hope this helps
SabrToothSqrl
yea
it's a PITA, i just let mine be off... if one gets low i'll check them anyway...
Mr. B
Rockford, IL
The same thing happened to me. I took it to the dealer and had them reset it.
BigRed76
SeniorGroupbuyMember
New York
TPMS Reset Procedure:
Turn the engine on to keep the battery charging.
Hold down the lock and unlock buttons on the key remote for 5 seconds, you'll hear the horn chirp twice and the DIC will say something about the procedure.
Go in this order and add/subtract air from the tire. The horn will chirp once to let you know when to stop letting air in/out.
Front left
Front right
Rear right
Rear left
After the rear left has been done, the horn will chirp twice, and you're done.
pistolpetem9
