WYO-HD
- Joined
- Feb 7, 2016
- Posts
- 89
- Reaction score
- 134
Finished fine tuning track width with oem wheels w/+31 offset. Started with 1.25" spacers on all four corners. After all was installed and measured, rear was out further, as most know when installing a lift with new knuckles and outer axle shaft extensions. Instead of going with thicker spacers in the rear, I ordered 3/8" front wheel spacers after measuring clearances. I already rubbed on the power retractable steps up front so didn't want to bring the fronts out anymore, but rather move them in since space was still available.
After installing the new 3/8" spacers, I had almost 5/16" of room left and a slite rub still up front. So we turned them down 3/16" that left me with a 3/16" spacer. Now installed the clearance between the upper a-arm/ball joint and inner front tire is 1/8". I took a flapper wheel and ground off the sharp lip on the aluminium a- arm.
All good now with a track width up front of 84.5" and a rear measurement of 84.75"....close enough for me and no rubbing on the retractable steps, even when in their down position. The measurement up front from ground to the bottom of the fender is 44", the rear measures 44.5".
Hope this helps some that may want to run oem wheels with a lift in the future. I know I had many questions in the beginning. BTW, have a set of the 1.25" rear hub/wheel centric spacers available if anyone is interested.
Site won't let me upload pics now, but will try later so you can see.
Cheers,
Cheers,
