Traction Active error message
shegarty
Hi all - I am getting the "Traction Active" error message and subsequent ABS activation again on my 04 Burb. It mostly happens after a cold start on acceleration from a stop. I say again because it happened a few years ago. At the time I was able to correct it with new front wheel speed sensors. I now have a laptop based Tech 2 and I was just wondering if there is a way to isolate and/or test the sensors and determine if it is one of the fronts that has gone bad again or if I should be looking to replace the rear ones. TIA
Fless
Super Moderator
Elev 5,280
With "Tech 2 Win" you should be able to view the wheel speed sensors in real time, as someone else is driving.
S
shegarty
That’s great - I’ll give that a shot. Any idea which menu those sensors might be located in?
Fless
Super Moderator
Elev 5,280
There's a Tech 2 pathing document in the post below, courtesy @Joseph Garcia.
madmoney
