I'm new, and I can't find this issue in a search.
2007 Tahoe. While driving, the truck shuddered a little and then the traction control/stability control light came on, the check engine light came on, the tach quit reading (stayed on 0), the alt quit charging (volts dropped to about 12 V on gauge), and A/C comp clutch cut out. All at the same time. When I got to a light I cut it off and waited about 15 sec and turned the truck back on. It had a long cranking period and then started. Same issue. Took off, and 1st to 2nd was harsh shift.
It only left a P0335 Crank Sensor code. No others. It sat for 20 min and then started fine. No check lights, alt charging to 14 V, A/C working fine.
Anyone seen this before?
John
John
