TRAILBLAZER SS Rear bag swap
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Seeing if there is anyone local in san francisco can lend me their truck for a day to do a write up on the trailblazer bag swap on any 00-13 truck.
The tbss bags fit in just need to do a notch for the ears up top and then you can use the airlift 72000 compressor to adjust it from inside.
At Normal psi it sits at a 3 inch drop and like the tbss they are rated to tow 6000 lbs. Truck will lay out rear on frame and at full lift be 1 inch lower than stock.
Bags would run you about $120 from a tbss
the airlift 72000 is about $430 side to side adjusatble comes with pump and all that
airlift 25812 side to side adjustable about $260
If anyone is interested please hit me up.
I've done the swap before but due to *** asking me whats involved I'd rather just show you guys.
nashon79
