Trailing arm brackets?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
how low are you?
Are you runnign the swaybar nwe links also?
93-306
I have a set of Belltech 4" springs on the back with shock brackets and Edelbrock lower trailing arms. Was thinking that the trailing arm brackets would get mine level with the ground again.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The trailing arms will do that I would also do the swaybar endlinks.
Did you cut the bracket off the frame?
the djm endlink kit and trailing arm kit i sell for 165 shipped if you decide to cut off the bumpstop brackets for more travel which will ride much better would be $190 shipped
93-306
Haven't cut the brackets off yet. I just pulled the bump stops off for now. I will be tearing into the engine this week and after that the bump stop brackets will be removed. Ill get with you soon to order the brackets and end links as soon as my wallet gets over my engine mods
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
No prob we just finished up a 408 with yank 3600 converter 4.10 gears on a 125 shot things a beast.
dylansmashed
