Trams fluid leaking from ujoints?
rs657f
hello,
I haven't driven the truck in about two months but I came outside today and noticed a pretty nasty fresh puddle of trans fluid on the ground. It seems to be coming from the front u joint. I don't see the seal leaking at all. I didn't know u joints could leak. I have a 96 Tahoe 2wd
drakon543
U joints dont leak they have grease in them not oil. Unless its starting to bind up and cook the grease. Its most likely the seal but only on occasion.
R
rs657f
thats the crazy part...the seal looks old but it is dry...i havent driven the truck and this leak wasnt there two days ago. this is a weird scenario. I know i did attempt to remove the k member about a week back to change the trans mount but i couldnt get the kmember bolts off so i didnt bother. Ill try to post a pic up of it, its still leaking like there is a weephold on there somewhere
starhawesjr
