Trans cooler lines won't fit in replacement radiator?
newbie78
I have a 1997 tahoe 5.7 and I bought a used rad at the salvage yard today out of another tahoe might be a yukon but from a 1996
Everything matches my existing rad but the trans lines do not fit in the new one. I'm so frustrated because draining all that coolant out was a mess and horrible job.
I went to pepboys and wasted an hour looking for brass adapters got home and they thread in no problem but the trans line does not seat and needs an o ring to seal it right?
I'm not sure what to do. All I know is the threaded part is 3/8"
Why would the trans cooler part of the rad be smaller?
N
newbie78
Not sure abput it being smaller but yes there are o-rings.
Yep definitely smaller holes for the trans lines on the replacement rad I got.
And I got the part numbers from my existing rad is 52469075 and the replacement is 52467234 :banghead::banghead:
Well $50 down the drain I'll never get back.
N
newbie78
So today was eventful to say the least. Started at 8am and just got done at 530 working on the replacing the radiator.
Since I got the wrong radiator from the salvage yard I swapped end tanks with my radiator that leaks coolant by the oil cooler line.
So I put it in and it leaks at the same spot! So then I had an idea to double up the gaskets to see if that would work. So I had to drain everything again and take it all apart again. So finally got it back together and leaks again same damn spot!!
So I just got done using JB Weld and loaded it up. The hardest part was putting it on with drips of coolant coming out. After it set for 20 mins not a drip to be found. I'm going to let it sit until monday to fully cure.
I just want it to get me through the fall and winter I plan a full cooling system rebuild in the spring with a new delphi rad, water pump, fan clutch, coolant temp sensor and superstat thermostat and all hoses.
Threw in an air temp sensor and IAC I got from the salvage yard today to see if that changes my high idle issue. Parts came out of a tahoe with only 100k on it. Worth a shot.
livingez_123
Sandy, OR
Why didn't you just get the right radiator in the first place? a few extra dollars then would have saved you all your time messing the junk yard unit.
N
newbie78
A few? Try $150 more I paid $50 for the one from the scrap yard. A new Dephi is $200 plus a water pump and the other stuff. Money is tight right now.
livingez_123
Sandy, OR
Well all the time spent running here and there adds up. If your WP isn't leaking, why replace it? I know all about how short money is, but better time management is worth $$ in the end.
$50 for a junk yard rad and what is your time worth? how many days?
Not trying to be a butt, just trying to make a point.
N
newbie78
Working on cars and trucks is also my hobby i enjoy it. Salvage yard is 20 mins from me.
---------- Post added at 12:04 AM ---------- Previous post was at 12:01 AM ----------
i payed bout 150 for my delphi unit on amazon
For a 1997 Tahoe? I just looked it's $350
dacpdx
