Transfer Case Switch Location
josetizapan
Iowa
Can anybody tell me where the transfer case switch in a 1999 Denali.
josetizapan
josetizapan
Iowa
I have a problem with my 4wd my truck keeps blowing the transfer case fuse and after that happens the switch in my dash has the red light turn on.
dsump
You have a short somewhere in your harness. Check all the connectors going to the transfer case.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Give me the t-case model if possible to verify and the specific fuse number. I will get you some charts and grams.
Where is this red light located and does it look look a symbol? Details, details, details...
josetizapan
josetizapan
Iowa
This is what compnine.com has for my vin "NP8 TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL TRANSFER CASE(NP8)". I belive is the number 2 and is a 20amp fuse.
The light is at the switch in the dash and its the light below where the word neutral is also the 2wd light and 4lo are also on il take a pic and load it up later today.
Rohdec72
