transmission problem.
99graytahoe
League CIty,TX
I have a 1999 chevy tahoe. 2wd. 138,459 miles on it. just yesterday my check engine light came on and i got the code read and it says that the transmission is slipping in the 4th gear. That same day i did notice alittle bit of slip and could see the rpm jump up and down when it did slip. My question is should i replace it with a rebuilt tranny with a warranty or just get mine rebuilt. if i bought another tranny, i was going to put it in myself with my father. how much are the 4l60e trannys going for rebuilt.
ezdaar
Chat Troll
Redneck central, Aka Houston
Go to this trans FLT LVL 3. I am having problems with their site right now, so I pulled some info from google cache.
4L60E-3 Street Performance – Level 3
Price: $1,595.00 (with core exchange - more »)
FLT machined performance pump.
Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
Seal & gasket kit
Bushing kit
Alto wide 2-4 red lined band with reinforced anchor
Bonded pistons/input drum
Sonnax SmartShell kit w/bearing
Extra Wide Heavy Duty double caged 29 element sprag
4L65 low roller clutch
Corvette servo
New solenoids
New internal wiring harness
New Spacer plate
B/W clutches
Updated aluminum accumulator pistons
FLT calibrated valvebody
Filter
Set end play to FLT specs
Case cooler fittings
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You must rebuild and for reference in Vallejo, Ca. 2 months ago the 4l60e costs me $2563 to overhaul with design improvements And that included labor for removal install about $600.
letsbangout
Corvette servo
I'm curious how that transmission shifts (and similar performance-minded rebuilds), particularly the 1-2 shift, with the corvette servo installed. I've read a few accounts on other forums where people have said they got a "performance" transmission that shifted way too hard, and they ended up un-doing some of the typical performance mods like the corvette servo or unblocking the accumulator.
pistolpetem9
