Dpsthomas
- Joined
- Mar 4, 2010
- Posts
- 61
- Reaction score
- 0
Hello all,
I have a 99 Tahoe two door sport. I had the transmission rebuilt about two years ago. I haven't had any problems until now. I used four wheel drive for the first time two days ago with all the snow we've been having. Well yesterday while driving home (in 2 hi) I noticed it shifted a little stiff into second. A short while later it wouldn't go into overdrive. It stayed in 3rd most of the way home. Then, about a mile from home it suddenly went into first. Now it won't shift out of first. I tried selecting each gear but it just stays in first. Reverse works fine. I tested the TPS, it's working properly. The speedometer works so I don't think the VSS has failed. I replaced the brake switch on the pedal just to see if it was the culprit but that didn't change anything. Does anyone have any ideas about what I should check next? I'm thinking it's something electrical but I don't know where to look.
I should also mention that there was a lot of snow stuck up around the transfer case.
---------- Post added at 06:32 PM ---------- Previous post was at 05:52 PM ----------
I forgot to add that there are no codes present and the fluid level is good and is red not burnt smelling or anything.
