Transmission woes?
5strmtrp
I’m at 155xxx miles on my SSV. Recently had some sluggishness that I thought was throttle related. Replaced TB & Gas pedal with little to no difference.
I check my fluids on the truck weekly to make sure all are up to capacity.
So here is my ?’s to you all…
The trans fluid is getting dark in color and smells burnt. So… I think it’s time for a rebuild. Last time I changed the fluid was around 125,*** give or take.
With the rebuild what is the general suggestion. Trans and torque converter, change out my sweating lines, replace the cooler with a larger one.
Would you also change out the transfer case as well?
Lane_Bo
