Transmission
uli93
on my 99 tahoe with the 5.7 vortec V8 the tranny shifts at high rpm when taking off it shifts around 5000 rpm into 2nd gear then drives normal but with a slightly high rpm it also doesnt drive while in reverse it wont move an inch when it is in reverse it sounds like the torque converter just whines kinda like a supercharger but not that loud i changed the filter and fluid but it made no difference has anybody had this problem?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
Copied from here
Slow, slipping or no reverse “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell.. May also have worn boost valve. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the Transmission may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmissionmission additive or other seal restorer product.
1-2 shift is delayed and harsh, may not shift into Over Drive CheckThrottlePosition Sensor (TPS).for smooth and linear electrical response over the entire range of motion. If not, replace.
QUYHMK
