Tru Tech S500 Amp SQ Clean Power
bolo1g2
SOLD
Hello selling my sub amp. I recently upgraded to Audison equipment so out with the old in with the new. Made in the USA power. Excellent SQ amp for those who want to push a sub. The amp is 10/10 for function, 8.5/10 for cosmetics. Comes with original box, packaging and manual. Amp bumps hard at 2ohms. Original retail is $800. I'm asking $200 shipped.
General info:- Full-Range Class AB Amplifiers - Dual Mono Design - 2 oz. "Plated Hole" PC Board - High Current Unregulated Bi-Polar Power Supply - Discrete Amplifier circuitry - 1% Metal Film Resistors - (16) TO-3P Audio Output Devices - (8) I.R.® 98Amp rated Power Inverter for Efficiency - Dual sets of High-Speed rectifier diodes - (12) 50 Volt 1,200mf Capacitors on Rails - 12dB Hi/Low pass filter (35Hz ~ 350Hz) - (1) 80mm Intake Fan, (2) 80mm fans on the Mono - Internal Heatsink - Variable Low Frequency Boost Circuit - Optional Remote Bass control knob - 4 Gauge Power/Ground Input - 8 Gauge Speaker Wire Output - Built in California, USA 325 x 1@4ohm, 500 x 1 @2ohm.
Capeles
