Turn signal/brake light bulb no worky
sloppydrippins
******, tx
Aside from my window problem, I got another. When activating my right hand turn signal yesterday I heard it clicking really fast. From what I've been told that means the bulb is out. I replaced the bulb with a brand new one but it still doesn't work and the clicker still goes fast.
Is there a fuse that handles just turn signals? Or one with multiple circuits that includes the turn signal circuit??
bowtiefreak
No Quarter
Near Philly
if it's the rear it could be the board back there. I have replaced both sides due to corrosion
sloppydrippins
sloppydrippins
******, tx
all bulbs checked
I checked the bulbs at all four corners. All look good. Can't tell if there's any corrosion on the board, either. That doesn't mean it ain't there, though. Also, checked the fuse and it was good. SNAFU.
DJTricky
Banned
Robbinsdale MN
i would try the flasher relay under the dash, i replaced mine with a solid state electronic one(regular flash/no click) its grate for LED's or adding in lights/trailers.
sloppydrippins
sloppydrippins
******, tx
bowtiefreak was right
I don't have much time to work on my truck so I had a garage fix it. Turns out it was that circuit board in the taillight assembly. No good. I would have checked the flasher relay too, but since the other side was working I ruled that out.
Thanks, bowtiefreak!
Danielj601
