I have a 2010 Yukon SLT. It has the back up camera and the mirrors rotate downward when in reverse.
When using a trailer, I use my mirrors for backing up. How do I turn this off?
Thanks
Upstate,
Press the customization button until PARK TILT MIRRORS appears on the DIC display. Press the set/reset button once to access the settings for this feature. Then press the customization button to scroll through the following settings:
OFF (default): Neither outside mirror will be tilted down when the vehicle is shifted into R (Reverse).
DRIVER MIRROR: The driver's outside mirror will be tilted down when the vehicle is shifted into R (Reverse).
PASSENGER MIRROR: The passenger's outside mirror will be tilted down when the vehicle is shifted into R (Reverse).
BOTH MIRRORS: The driver's and passenger's outside mirrors will be tilted down when the vehicle is shifted into R (Reverse).
NO CHANGE: No change will be made to this feature.
The current setting will remain. To select a setting, press the set/reset button while the desired setting is displayed on the DIC.
This information was found in your owner’s manual on page 4-76. I hope this helps!
Thank you!
Elizabeth, GM Customer Assistance
