Tvs2300 jack shaft
Price32
Colorado
I've got a tvs 2300 jack shaft on its way, but I didn't get a complete kit. I'll need injectors and intake tube. My question is what type of injector would I need to support the Maggie? I'm getting the fuel pump upgraded with the walbro 450 intank pump just want to make sure I have the right set up. Also, I'm here in Colorado at high altitude and my compression is at 10.5:1, with a 10 rib pulley and 12psi will put me closer to 8-9 psi at altitude, but what negative effect will it have if I were to drive my truck to a lower altitude like Arizona at that compression ratio?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
You should be fine, but it might be tough getting that blower up to 12psi, you will definitely need 2.6 blower revolutions for every engine revolution. Final pulley used will depend on what the rear pulley setup is on that jackshaft. Going to a lower alt won't be a problem, as long as the system is running well and tuned well. Definitely make sure you are running good quality fuel.
I am running ID1000 with my TVS2300.
Price32
Price32
Colorado
That's good info, thank you! I'm excited as hell and looking forward to seeing how she wakes up once everything is done.
