U joint replacement
Johnb21
Hi all. Just wanted to get your take on replacing both the front and rear driveshaft u-joints with AC Delco 45U0110. These are the non-greasable type. The originals lasted over 160k miles on my 2005 Tahoe 4wd LT, so I figured this might be the way to go. Actually, only the rear needs to be replaced, but I thought while the driveshaft was out to just go ahead and do both. I love to lift the hood on my vehicles, but losing interest in remembering to lube up a greaseable joint.
Thanks for your thoughts.
drakon543
If your doing u joints i would always suggest to hit them all while your doing them. As far as greasable vs a sealed u joint either one will probably outlast the truck at 160k. Previous vehicles i haven't seen a big price difference between the two so i generally just default to the sealed style first when available.
J
Johnb21
Thanks for the advice Drakon543!
01ssreda4
Non-greasable is a stronger joint because it is NOT hollow inside for grease to flow through. Food for thought.
ATIII
Brighton, CO (Denver)
Running these, They are listed as greaseable, but they aren't. Work great!
ACDelco 45U0136 Professional U-Joint
shadowid60
