gmartin1215
- Joined
- Nov 9, 2012
- Posts
- 245
- Reaction score
- 105
I have a 2009 Tahoe LT that has a 2" leveling kit on it now. I am going to be refurbishing the entire front end suspension and will also be installing a BDS 4" coil-over kit.
I have two UCA possibilities for my rebuild, Zone C2310 and the Moog Problem Solver.
I was thinking the Zone would be a good compliment to the BDS 4" that I will be installing, and they state it will have more droop or wheel travel over stock (and probably more than the Moog, too).
I was considering the UCA from BDS, and even Baja Lifts, but those arms are way more $$$. The Zone UCA was more towards the middle price-wise of the higher-end arms and Moog
The Zone UCA is definitely beefier than the option from Moog. You do need to weld on a steering stop to the LCA that I am not too keen on the idea. Ideally, I would get the BDS UCA to go with their 4" kit, but those arms are near the $800 mark where Zones are around $450. However, I am wondering if these Zone arms will be a bit more overkill than I need, and they are much more cost-wise than the Moogs. I did chat with the BDS tech line and the person there said they usually recommend just using stock control arms since all the correction has been made at the knuckle.
I plan to make my Tahoe and overland rig that will see mild to medium difficulty trails. However, since I will be rebuilding the front end anyway, I want to do it with the best possible parts and have the best possible capability outcomes without too much overkill.
Given the above, what direction would you swing, Zone vs Moog, and why?
