95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,155
- Reaction score
- 4,455
I picked up a new lock for the barn doors its uncoded so has to be coded to my key to match the other locks is that easy to do? Or is it best bringing it somewhere?
Yup its complete, changed the front two doors (new locks and keys) had someone try to break into it and broke the driverside lock so just replaced them, need to match the new lock to that key, ill most likely bring it somewhere thenDid it come with the tumblers? If so, take apart your old cylinder. The tumblers are numbered or lettered. Just do one at a time and put the spring / tumbler from the new set in the correct order. Make sure to lube it up.
Wish it was that easy, see above postor take what is likely your worn key and have a locksmith match it to that for easy action.
