DonaldPerry
- Joined
- Mar 26, 2024
- Posts
- 2
- Reaction score
- 4
Is it normal for the driver's side to have cooler "heat mode" air when bottom vents are used, compared to the passenger side when both sides are set to the same temperature?
Is there more than one blend door than the one on the passenger side left of the glove box?
The actuator for the above blend door operates correctly, as does the mode actuator.
Is there more than one blend door for the Heat/AC system (i.e., one for the driver and one for the passenger)?
Everything works as it should except for the uneven heat air temperature.
Thanks!
Don
Thanks!
Don
