"Unknown Driver" cluster issue
srtwhat
Alexandria Va
Recently my 03 Yukon keeps going into "unknown Driver mode". All the gauges on the cluster stop working but the tack and the speedo. The ABS , Airbag and battery light all turn on. This happens randomly and hardly never happens when I first turn on the truck. Lastly the cluster is new and the previous owner I think had an after market alarm installed at one point because it looks like a rats nest under the dash. Does anyone have any ideas what is causing this to happen?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Does it do this for both keys/fobs?
If so it is probably an issue with the Memory seat module located underneath the driver's seat.
You can try disconnecting your battery and doing a "reset" which drains all capicitors in all modules by holding both positive and negative battery cables together for 5 seconds or so and then reattaching them to the battery.
srtwhat
srtwhat
Alexandria Va
I currently only have one key\key fob .......i recently replaced the key fob and i cant remember if it was doing this before. I will say the old cluster was not doing this but i dont think the old cluster was for the truck
srtwhat
srtwhat
Alexandria Va
I finally figured out the issue , the cluster that the dealer gave me was bad....... luckily it came with a warranty, i got it swapped out and now everything works fine
patniven
