eanthonyc71
- Joined
- Nov 16, 2015
- Posts
- 5
- Reaction score
- 0
Has anyone done this? Is it plug and play or do you have to do lots of wiring to fit it..
Because LTZs have better headlights.why do you wanna do that???
Very interested in seeing if these worked for you.
they arent the same. they look the same from outside.The LT and LTZ have the same headlights. It's just the BCM is programed differently for the LTZ to have only the LEDs to be the only DRL while the LT uses both the low and strip. This is probably due to the LTZ having HID's and you wouldn't want them on for DRL's all day.
My buddy is a tech for GM and he's going to be trying to load up the LTZ light protocol into my LT BCM and see if we can get the DRL's to function as the LTZ's do.
The led strip is a completely different color on the LTZ. The LTZ has HID headlights, the LT does not.
so that means all I have to do is install the LTZ headlights into my suburban LT and that itThe led strip is a completely different color on the LTZ. The LTZ has HID headlights, the LT does not.
