urgent help on tpms
VikingTrad3r
i have my 06 denali xl and for this winter i am looking at getting a set of 20" avalance rims that have the tpms in them.
will the toms from the 07-14 gen fullsizes "connect" with the 99-06 gen?
i found the relearn procedure but what i am after is if the sensors changed so they are incomptible or if they will all work.
cheers. im driving to look at the rims now.
V
VikingTrad3r
Thnx Nathan. I have also read they will as long as they are the 315mhz. Which they are.
That said, have you tried it yourself and they have not worked? Cheers, VikingTrad3r
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I had tried relearning in my 07 from some rims off a 04 and it didn't work.
If you look up sensors on Amazon, there's different part numbers for 03-06 and 07-14.
V
VikingTrad3r
in the end i just kept the 07 avalance rims, removed the tpms and resold all 4 for 50$. cover half the cost of getting my winters mounted.
Lilmule
