WoldD90
Off Road Addict
HIGH AMPERAGE/ HEAVY-DUTY ALTERNATOR/ CHARGING SYSTEM
Applications 88 - 95 Chevy and GM Products, 4.3, 5.7, 6.5, 7.4 and 94-95 Chevy/GMC Diesel Motors (All C and K style trucks). Per PPW, it can work on a Jeep with a custom bracket.
Up for auction is a Premier Power Welder Alternator for GM trucks, model number PW170. This can be used with or without an on-board welder.
Please contact Premier Power Welder to determine if this will suit your application. I planned to use this on my trail truck, but went in a different direction.
The package here includes the alternator and the older style regulator. Everything is in great working condition and it has been serviced and tested by a local alternator shop where a diode was replaced.
Specs
Hand-wound stators
13-gauge copper wire (above industry standard
Dual plain balanced rotors
Double-greased, sealed bearings (rated at 20,000 rotor RPM)
Low leakage, special high-amperage diodes
Specially designed longer brushes -- longer life, up to 40,000 miles more than the industry standard
Premier regulator is the state-of-the-art design that produces higher output ratings than the current industry standards with extruded aluminum heat sink for more efficient cooling
Regulator has ground-fault protection and high-voltage protection
All electrical connections are standard
Standard OEM belts can be used in most applications
Standard OEM mounting -- no brackets needed
Two (2) cooling fans to dissipate heat
Specially designed heat sinks that make the diodes run cool
Weighs 11 pounds
Specs
Hand-wound stators
Weighs 11 pounds
