Vacuum Pump Delete - Great New Option
BMPNUGLS
Mid-MO
I ran across this recently while searching for options for a vacuum source when deleting the vacuum pump and thought I’d share. Pretty good idea/product - allows you to keep your catch can vacuum port without adding a TB spacer tapped with a port…
Video:
Product now available:
TireFire
I like it. Basically a glorified T into the evap purge line? I’m starting to look into vacuum pump removal since I’m now out of warranty and have DoD turned off. Couldn’t believe one of the most popular YT videos on the subject instructs folks to delete PCV
BMPNUGLS
BMPNUGLS
Mid-MO
I finally got around to installing this part today and got rid of the vacuum pump. Brakes (brake booster) seems to work a bit better with the vacuum source switched to manifold vacuum.
Chaveztech510
