valve cover
fejcharson
I took off the valve covers on my 2001 Chevy Tahoe 5.3 and the top of the drivers side cover was coated in a thick light brown sludge. The passenger side looked normal. I have been losing coolant for some time now but haven't been able to find where it is coming from. Does this point to a cracked head or is this normal when a valve cover gasket is leaking? I have some pictures below what the valve cover looked like.IMG-1626.JPG IMG-1627.JPG
Thanks,
Jeff
That's what I was thinking. Is there anyway to know if its the cracked head or the head gasket? I cant't see the casetech logo on the head to tell if it was part of the bad ones.
Well, you can pull the rockers and pushrods and look down in there for any obvious cracks. Alternatively, you can pressurize the cooling system and look there again but the bolt holes under the valve covers are common places for cracking too.
I'm sure someone will chime in with a better way and more experience. Hold tight.
SnowDrifter
Washington. The desert side not the Starbucks side
Visual inspection is pretty much the way to go. If you need help, you can get UV dye you add to your coolant then shine a blacklight around. Either way: Heads are going to have to come off. The only question is whether or not you're decking them or replacing them
based on previous reports I would have to lean towards a cracked head, blowing a head gasket on these engines is almost unheard of
afpj
Get an oil analysis from Blackstone labs, that can give you a clue if you have excess bearing wear if lead an iron are high (IIRC)
SnowDrifter
IIRC
Bearing wear would be lead, and depending on the bearing comp, copper too.
Iron would be cylinder walls, timing set
Chromium from the rockers
Molybdenum/aluminum from pistons and rings
BrancoRST
