Vanquish Auto lights
Denali132
Banned
So I finally have pictures of all my Vanquish Auto bulbs. I have HIDS for low beams and LEDS for high beams. LED for tag lights and the new really bright LED back up bulbs still working on. Also my fog lights are the 120 watt LEDS.Love all the lights they look good and are really bright!5c8cf0e59e7c18442e63bf4d8161f13f.jpg99cda0fc281d7c24ddbc93bd22865b36.jpg28cdfe68ee7448f0bf896ab33dadf486.jpge8edf1f2d938636eaf608efe292cfaf0.jpg0bd425b0140ed6a349c399f3bdff1db7.jpgd5e078a197de59408b52737e1c3b53c1.jpg
Sent from my iPad using Tapatalk
Denali132
Denali132
Banned
That is awesome Frank, can't wait to see the new backups
You have great products and really like the look and quality. And your customer service is second to none! Any time I had a question or suggestions on which ones to choose is great! You respond back very quick. Thanks for all your help!
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
We are here for that, our customers are our priority and you are high priority for us!
yukonchief
old thread..... but i got a question? Why did you go with HIDs in the lows rather then the LEDs? Do the LEDs not produce enough light then stock halogen bulbs?
BADRIDES
Curious on this too
CMoore711
Here'sa good thread: http://www.tahoeyukonforum.com/threads/led-vs-hid-headlight-upgrade.95293/
LED headlight technology is still relatively "new" and its rapidly improving. Right now LEDs have the best success when used for DRL lights, reverse lights, fog lights, interior lights, etc.... but lack the true penetrating beam pattern needed for low beam lights. The LED lights do not produce a halogen type light pattern and also the projector housing you have is expecting a halogen bulb to be placed in it. They have designed the headlamp housing to know the halogen filament will be X inches from the tip of the bulb and precisely angled all sides to reflect that light forward infront of the vehicle. The thing with LEDs is most commonly, where the LED lights are on the bulb and are producing the light are not exactly where the housing is meant to reflect light. So a lot of the light is not reflected into the correct direction and light is lost inside the headlamp. Also, the pattern of the LEDs is to push light in only two directions on the bulb, where a filament of HID bulb does it in a true 360*. (there are 360* LED lights also, they are even worse than the normal LEDs that are only on the two sides). So in a brief summary, LEDs are great, they use a FRACTION of the power than HIDs or Halogen, they do not get as hot either, they are straight plug and play, and they go from 0-100% light out put instantly. BUT, they are still lacking in the true directional light and penetrating light. They are better than stock halogen, but not better than HID kit.
BLS9
