want to bag my yukon
Lapolarbear
Need sum help ive been lookin for a kit for the rear to bag my yukon but nobody sells it ready to install do any of yall know where i can get one from or have pics of there's so i can get an idea of what to do
NASTY GM
Nor Cal
Mine is an 07 but the only thing needed were the rear bags. They went in place where the rear springs were. All the rest of the suspension is the same. We did move the panhard bar, so the rear end was centered when down.
yates ™
Resident Apple hater
Iowa
I don't think there is a direct bolt on for those.
foreverfalcon40
That is for towing...but if you start cutting the frame and make custom brackets you should be good.
AtomicHoe094
Atomichoe094
cleveland, OH
there is a bolt on kit or well mostly bolt on.. made my air ride technologies. It wont lay frame but its a starting point..
foreverfalcon40
My idea...is to use to the firestone kit as a starter...then install your c-notch and hangers. From there build custom brackets...so when I tow I won't completely bottom out. Right I am having issues with around 1,5 to over 2k. The rear diff made a nice circle dent in my trunk area :)
Since I installed the train horns I am a little step closer since I already hve the tank and compressor mounted in the quarter panels behind the interior panels.
AtomicHoe094
Atomichoe094
cleveland, OH
falcon- your hitting your rearend on the floor of the truck??
That cant be right, i have close to an 8 or 9 inch drop in the rear and im no where close. ill be actually raising my rear since its too low for me..
foreverfalcon40
Oh Hell the dif hit the trunk floor. Its snow here, I will post pics. Until then I will STFU :)
So lucky my brake lines never snapped but there are all SS now so it helps alot.
haloOne
