want to install air bags on 99 yukon with 24' rims?
dboy24's
phoenix,az.
I have a buddy selling me his air bagg kit all I need is the compressor and tank but how hard is it to install them on my 99 yukon and what do I need to do to my truck for the baggs to fitt I have 24' rims u guys think its a good idea
AtomicHoe094
Atomichoe094
cleveland, OH
Everythings possible with the right amount of money and a good fabricator. front and rear?
For the rims, you just have to worry about your backspacing as it can hit the lips of the fenders and such, deff have to tub out the rear and take off the inner front fenders..
dboy24's
dboy24's
phoenix,az.
Im a structiral steel fabricator so I can build cut and weld anything but since this is a used kit and ive never done this im wondering what I need brackets spindles and stuff like that? And yes I want to do front and back ...my buddy had this kit on a. 80's Chevy truck
groundscr8pr
flaccid member
scarborough maine
standard 2wd 1500 pickup front brackets, spindles, custom a arms notch the frame for tie rods should do the front. the rear will be all custom. check out streetsource.com. search owner profiles. there are alot of builds with pics.
NASTY GM
Nor Cal
Are you just bagging it or laying it out? Just bagging it wont be hard, but the lay it out is a lot of work.
dboy24's
dboy24's
phoenix,az.
I just want to bagg it ..this is my evryday driver dont wana lay it YET.. But I will some day
---------- Post added at 12:27 AM ---------- Previous post was at 12:24 AM ----------
Nasty did you bagg youre truck youreself ?
groundscr8pr
flaccid member
scarborough maine
airride technologies used to make a kit for the back. its not on the site anymore but if you called them they might find on for you. it was an all bolt in 4link kit.
NASTY GM
Nor Cal
Mine is just bagged, for now.
Mine is a NNBS but heres what I have.
Front
Dropped spindles
Strut bags
Belltech adjustable struts
Rear
Contitect bags (where the springs were)
Belltech shocks
Steelbraided airlines
AVS box
Viair 480 compressors
Two 3 gallon tanks
Asco valves
Pretty simple. I paid $4400 cash for parts, powdercoat and installation.
foreverfalcon40
If you can fabricate then thats 60 percent of the battle. Rest is balls and money. Def look into rolling your fenders for tire clearence. Keep us posted. Check out Fullsizechevy.com alot of guys bagged and laying frame are on there! GL!
Black1996
Im looking to do the same with my yukon 2 door. Im wondering if i get a setup that runs about an inch higher than stock all around fully inflated and as low as i can from there while still being able to utilize my factory 4x4 system. im running 305/35r24 tires with an 1.5" offset spacers in the back. Im not in a rush to get this done but id definatly wanna take a run at it this winter if i can get enough info and money lined up. Any info would be appreciated!!
haloOne
