Water Intrusion
Gyrene84
My 2005 Tahoe has some water intrusion on the passenger side footwell. I assume it's coming in from underneath, as I have Husky floor liners and I only noticed the carpent was soaked after I pulled them out after a road trip. Drove through torrential rain for about 3 hours.
Is there a plug or common hole I should be looking for?
Dan Acosta
Check under the wiper cowl cover (you have to remove the wipers). On the right side (pass), there is a fresh air block off plate that gm did a horrible job of adhering. It will need to be removed. and re-sealed - maybe with silicone. The other options would be if the sunroof drains are clogged, and finally is to check the bottom of the fender for leaf accumulation. It can be accessed when the door is open and you remove the small rubbery block of piece that is kinds shaped like a triangle. Once removed the leaves can be hosed out. This causes rain and road water to enter through a higher than normal portion of the door seal, sometimes through wiring/door switch grommets. I pretty much had to do these to fix my leak issues. Of course if it smells like coolant then it is a heater core leak, but not common on these.
janabanana
