Water leak on pasengers side floor.
02Lightning
Looks like I have water leaking on the floor mat on the passenger’s side front floor. I put my hand under the dash and I can feel water on the lip of the fuse box door on the side of the dash. Anyone have any ideas where I should start to look for this? Isn't the sunroof drain in the A-pillar right there in the door seal?
02Lightning
02Lightning
2008 Yukon Denali water leak?
Looks like I have water leaking on the floor mat on the passenger’s side front floor. I put my hand under the dash and I can feel water on the lip of the fuse box door on the side of the dash. Anyone have any ideas where I should start to look for this? Isn't the sunroof drain in the A-pillar right there?
moosehead
Do you have a sunroof? If so it's likely a plugged drain tube.
MACHO
Seattle, WA
I just posted something similar. Leak coming out above the seatbelt. Thought it was my esky rack and couldnt find anything on google until some members suggested it was the sunroof. Then searched again and found some diagrams of the sunroof drains and where they went. Haven't taken it to the dealer yet to confirm but it makes sense that they're the culprit
02Lightning
02Lightning
The second diagram looks like the A-pillar. More than likely that is it. I guess I could get some wire and run through it and maybe some compressed air to see if it's clear.
mhessick
