drakon543
- Joined
- Feb 15, 2016
- Posts
- 2,473
- Reaction score
- 1,715
are you referring to the vent selection settings or when you adjust the temperature. you should have 2 actuated doors for the hvac. one is typically audible and that would be the vent selector door. the blend door mixes cooler air with the direct heated air to get your desired heat setting. the blend door as mentioned above is the door in reference. if its weak it could be opening farther than it should be allowing too much cool air in the system.Thanks all, coolant temp guage in dash it dead middle 210ish degrees.
Im hearing the door change settings but it seems to me slow.
The hoses are warm hot on the top, like it should be, cool on the bottom.
I didn’t check the hoses going to the heater under the hood, will check when I get home tonight, see what they feel like.
