WDT Plastidip LOVE - Plastidip Pearlizer - MUST SEE
baggedlvintegra
Fort Worth, TX
So I have played with Plastidip on several other applications and this stuff is absolutely AMAZING. Recently they introduced a new Plastidip Pearlizer so of course I had to give it a try and I must say, I AM IN LOVE!!!! Barely played around with it a little bit this evening and I must say for a universal generic pearl spray it matched the stock WDT pretty well. The following is base coat normal matte white Plastidip, 3 full coats Plastidip Pearlizer and Normal Rustoleum Automotive Clear Coat (not even wetsanded yet, will do so tomorrow once fully cured). Here are some pics...I did the full Plastdip job on the hood trim molding, the emblems are merely 1 coat of white with the Pearlizer sprayed while it was still wet, so you can see it slightly lighter and thin on the edges....overall I am IMPRESSED, now I can save big $$$ paint matching out all my trim!!!!
without flash
with flash
Products Used
If you've never seen or heard of Plastidip before, check this vid:
http://www.youtube.com/watch?v=xj68Jji57w8
MACHO
Seattle, WA
I'm a big fan of PDip. Didn't realize they came out with a pearlier. It looks fantastic bro!
Blazed
Accepting Donations
If you clear coat plasti dip it's a complete ***** to get off plus I read that plasti dip takes about four days to cure fully! Just leave it as is you'll make it worse on your self.
---------- Post added at 03:25 AM ---------- Previous post was at 03:25 AM ----------
Looks good tho
baggedlvintegra
baggedlvintegra
Fort Worth, TX
looks just as good if not even better match in the sun...
I now have a weekend project to do the fender vents, door moldings and rear lift gate applique :)
Caddychris
