Weird Noise From Suspension
rwiegand
2017 Yukon Denali with Magnetic Ride. The driver's front suspension is making a noise that sounds like an owl hooting or a pigeon cooing. The noise stops when it is really cold outside. The dealer said it is coming from the bumpstop / jounce stop, but they want $1,100 to replace both front bump stops and won't guarantee that will stop the noise. The noise occurs with even the slightest movement of the suspension. Does anyone have any idea if the bumpstop could be causing such a sound, or any other ideas what it may be? Thanks.
Welcome to the Forum from NH.
Pics of the truck, please.
I'm not sure how the bump stops could be causing this issue, and the quote to replace is through the roof. I'd be checking the bushings on the sway bars (first choice guess) and on the control arms, to see if there is any visible deterioration.
