BigDaddy13440
This is an easy way to figure out what size the tires you have really are, or what you are looking at buying.
For example: lets say a 265 / 75 / 16
265 is the cross sectional width in millimeters - divide by 25.4, this will give you the tire width in inches - 265/25.4= 10.43"
75 is the percentage of the width that the sidewall height is - 265x.75(75%)= 198.75mm - divide by 25.4 = 7.82 this is the height of the sidewall in inches
take that 7.82, and double it = 15.64 - you have a sidewall on the top AND bottom of the tire, right?
add the 15.64 to the rim size (16") - 31.64" is the approximate size of a 265/75/16 tire mounted on a 16" rim
Now, for a larger size.... say a 345/60/20
345/25.4= 13.58" - width of tire
345x.60(60%)=207mm, divided by 25.4= 8.15"
8.15x2= 16.30, add rim size of 20", overall tire height is 36.3"
And you can do the reverse.
Say you want a 33" tire, with a 20" rim.
33" - 20"= 13" total sidewall height, /2 = single sidewall height of 6.5"
6.5 x 25.4 = 165.1mm
if you want a 50 series tire, divide the 165.1 by .5 = 330.2
since 330 isn't a standard size, you'd go up to a 335/50/20, which would be just over 33", or use a 325/50/20, just under 33"
Comprende???
Comprende???
