What else should I replace when I do my rear main?
eph1zzle
Hey guys I have the infamous rear main leak so ill be doing that along with the oil pan upper, lower, valve gaskets, and tail shaft seal. I was thonking about replacing my oil pump while im fown there. Is there anything else i can bang out while ive got her tore down and on the lift? 2000 yukon slt 5.3 with 111,*** miles
hoe
a Circle D 285mm 3200 torque converter
x2 perfect time to update the Stall Converter while its separated. You will not want to do it again, if you plan a stall in the future.
E
eph1zzle
So these are all the seals and gaskets im redoing
Rear Main
Valve Cover Seals
Valve Cover Grommets
Oil Pan Gaskets
Crank Shaft Seal
Water Pump Gaskets
Tail Shaft Gasket
Front Cover Gasket
NC_John
North Carolina
I changed my rear seal and rear engine cover gasket. I had already done the oil pan previously. I changed a couple seals on the transmission and did a service on it but didn't get into to it too far. If its not leaking, don't f*ck with it. The rear end was dry so I didn't change any seals on it.
Gotcha12
