Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Where should the engine oil pressure gauge indicator be at when the engine is warm?
Is there any limitation for the gauge Indicator?
Tahoe 2013 5.3L, 4WD
Thank you.
20 PSI for a hot idle is usually normal. Not 100% sure how that translates to the metric gauge but 20 PSI is the first mark on the US models. The low oil pressure message doesn’t come on until 6 PSI though.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
